New clutch Install question
Just installed a new clutch... everything's in place except the transaxle. Should the drive shaft (torque tube) be able to spin freely or should it be engaged with the clutch and only turn with the engine?
Was the clutch depressed when you tried to spin the drive shaft? If it wasn't, then I'm fairly certain the drive shaft should be rotating with the engine. It doesn't make sense for it not to, as the only thing keeping it from rotating with the engine is the clutch.
