944 blowing hot then cold from vents
My 1988 944 is blowing alternately hot air and cold air out of the vents mostly hot air as if the interior climate control is set to the hottest setting, it is set on the coolest setting, do I need a new climate control sensor? and if so where is it located? any other possibilities?
Thank you
Thank you
