944 Vibration Question
When my 87 944 is at idle I have a very bad shudder/vibration. When I give it gas and the rpms go to around 1100 the car is as smooth as silk. I have only had the car a few weeks so I don't know much of the history about it. My first take is that possibly the balance shafts are slightly out of adjustment. But I also notice that the idle RPM's fluctuate between approximately 800 to 900 rpm (constantly when at idle) This could possibly be a bad Idle Stabilizer. What do you think?
Thanks Terry
Thanks Terry
Thanks Terry
Thanks Terry
I had such a bad vibration that i couldnt believe it was just the motor mounts - i replaced them both (you should do both if you're going to do either) and it make an unbelieveable difference.
