shifting question ..HELP
short and to the point all and any help appreciated
i have an 89 s2
ratteling sound from under the car sounds likelike a loose heat shield but started whith shifting issue
hard shift lever very tough to get into gear
cant change gears unless i pump clutch pedal a couple of times
clunking under accell/decel
my questions are do the 89 s2's have the rubber coupler?
does this sound like a bad throwout bearing? i thought slave but that doesent explain the clunking and ratteling sound
the clutch does not slip
i have an 89 s2
