944 & 944S Forum 1982-1991
89 s2 timing belt questions need advice FAST please
Old 06-21-2009, 02:39 AM
prossi
prossi's Avatar
Default 89 s2 timing belt questions need advice FAST please
i just bought an 89 s2 for a great price but the timing belt slipped due to some teeth shearing off. the car was idling and this happened when the po tried to take off so it was all at low rpms. my question is do i need to replace any valves since this happened at low rpmsand the belt only slipped?
Old 06-21-2009, 05:58 PM
931guru
931guru's Avatar
Yep
Old 06-21-2009, 11:43 PM
N_Halbert
N_Halbert's Avatar
Speed and RPM have nothing to do with it. The head design is interference. You will need to replace 4 as a minimum. Then there is the "while they are in there" jobs. Gaskets, seals, cam tensioner pads, water pump if origional......
Old 06-22-2009, 12:29 AM
Mikes3.0cabturbo
Mikes3.0cabturbo's Avatar
depends on how many teeth the belt slipped, I know with three teeth out of alignment I had the valves touching slightly....
Old 06-22-2009, 08:48 AM
TF
TF's Avatar
You need to take the head off and look
Old 06-22-2009, 04:21 PM
eohrnberger
eohrnberger's Avatar
Yup. Just been through this myself.
Valves, but probably not all of them, only the bent ones. May as well get the valve seals redone, and if you had thought of getting the valve seats cleaned up (machined), now'd be the time.
If you were thinking of a light polishing of the intake runners, now'd be the time as well.
If your chain tensioner pads are worn, now'd be the time as well, but it's pretty easy to get at that later. Either way.
Make sure to magnaflux the cams to make sure that the teeth on the cams have not been weakened. This is usually a low cost item (perhaps even free) at a local, reputable machine shop.
Old 06-29-2009, 10:06 AM
prossi
prossi's Avatar
ok, so i changed the timing belt this weekend, did a compression test had 160 across all 4 cylinders, so i started her up and ran as smooth as butter... did i get lucky here or am i missing something ? it seemes the old belt had sheared about 6 teeth off.
Old 06-29-2009, 08:42 PM
Tom Carson
Tom Carson's Avatar
buy a lottery ticket...you are on a roll !
Old 06-29-2009, 11:08 PM
prossi
prossi's Avatar
i may take your advice..took her for a spin and runs beautiful!!!!!...guess i dodged a bullet here, i kind of feel bad since the po let it go so cheap due to the rediculous quote he got to fix it, first time ive ever won gambeling
Quick Reply: 89 s2 timing belt questions need advice FAST please
