pls Help- oil pump quastion?
hi,
can someone please tell (as i forgot ) if to change oil pump i will have to take apart the cylinder head??? as i have some oil leaks from the oil pump and the flywheel ...
According to the clarks-garage instructions it looks like you do not have to as it should just slide off the crank.
http://clarks-garage.com/shop-manual/lube-07.htm
If you are removing the oil pan then it is a larger job, at least from what I have been told.
