Need any parts??
Need any parts??
This weekend I'm buying a 1989 S2 for parts. Everything works but some of the body panels have been vandelized.
The car is black with a cashmere(?) interior and has about 74K on the odometer.
Let me know what you'd like and I'll see if it's available.
Engine is taken...
Engine is taken...
I needed an exterior handle, I wound up just ordering one online. Those things are a lot more of a pain in the neck to replace then I thought so I just bought new. Thanks anyway.
There is a screw right above the latch on the door, take that out. Slide the handle towards the front of the car and pull out on the side that has the tumbler. Disconnect the white plastic linkage for the lock, then with the window down, use a long screw driver to pop the black plastic eyelet off the latch release linkage. On the side of the tumbler there is a plastic connector with a white wire going to it. This gets popped off sideways. Then pull on the lever in the handle to make it easier for the linkage to get out of the little hole. To get a basic idea go to www.clarks-garage.com . The s2 is a little different then what is on the site but the pictures do help what I said make sense.
would you take a hundred for the dme ?
