91 S2 battery discharging problem
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Check the switch in the door jam -- that has been the cause of slow battery drain problem for others in the past (do a search for old threads).
Originally Posted by saalboy
Hi Joseph,
Would you, please, tell me what do you mean by cheking the door jam switch. What does it do? Is that a cabin light switch?
Thanks, Alex
Thanks, Alex
Yes, they can malfunction and cause a drain. Have you used a multimeter to test the drain at the battery with everything off? search the threads here and in the 944 forum for battery drain and you will get the normal readings. I can't remember them off the top.
Hello everyone!
Any idea why the battery looses it's charge while a car is parked for longer than a couple of weeks.
Thanx
Thanx
1> diconnect battery earth
2> Connect a meter (amps)
3> one terminal goes to the disconnected earth lead/ other to the battry neg
4> DO NOT ATTEMPT TO START CAR
5> check the reading, can't remember what they usually are, only about 10-20millioamps
6> then pull one fuse out at a time
7> when the reading goes down a lot, you've found the source of the current drain, look up on the fusebox and see what that circuit looks after
here are a few suspects
1> boot light
2> hood light
3> interior light
4> glovebox light
5> alarm
6> stereo
hope this helps
