944 & 944S Forum 1982-1991
Biggest tire size on stock rims.
Old 12-05-2004, 03:11 PM
1QUICKS2
1QUICKS2's Avatar
Default Biggest tire size on stock rims.
Whats the biggest tire size you can have on stock rims on an S2? Is anyone running the same size tire combo on Front and rear?
Old 12-06-2004, 06:19 PM
N_Halbert
N_Halbert's Avatar
On Stock rims
front 7's: 225x50/16 rear 8's: 245x45/16 Much larger and you get too much round over and rub, with out lots of camber. I have heard of 255's on the car but that is with 9's.
Same size front and rear?
Yes, 245x45/16 but on 8's at all four. You can run 225x50/16's on all four but don't want to rotate the fronts to the rear. The main reason for the same size all around is to facilitate even ware by being able to rotate the tires to any position. 225's on the front will improve sick but the side wall height and overlap may cause the car to feel numb or less responsive.
With wider tires up front you will get more tramlining and more kick back.
For more info just go and search for tire sizes. You will find a boat load of input.
For street use the stock sizes work well and are the most cost effective.
Quick Reply: Biggest tire size on stock rims.
