944 & 944S Forum 1982-1991
944 speedo problem
Old 08-07-2004, 06:41 PM
GAVMAN
GAVMAN's Avatar
Question 944 speedo problem
I have just purchased a '86 944 and have found the speedo to be reading 10-15% fast. Is it the speedo probe in the gearbox ? Any ideas ?
Old 08-08-2004, 01:06 AM
924martinirossi
924martinirossi's Avatar
Does it have stock tires on it? I run 50s on mine and my speedo is about 3.3% slow.
Old 08-09-2004, 02:44 AM
GAVMAN
GAVMAN's Avatar
Default Stock tyres
Yes, It has stock tyres on it. The Tacho is reading correct at the known correct speed. But instead of reading 60MPH it is reading 70MPH.
Do you or anybody know about calibrating the electronic speedos.
Old 08-09-2004, 11:42 AM
Kurt R
Hates Family Guy
Kurt R's Avatar
Is the odometer (mileometer) off too, or just speed. The sender in the transmission just counts revolutions of a gear, there is no way it would be off 10%, except maybe 10% low if it was failing and missing counts. It could be your speedometer is failing if the mileage is correct, or if the mileage is off too then maybe the speedometer was replaced with one from a different car with a different final drive. There are places to send the speedometer to have it recalibrated, where are you located?
Old 08-09-2004, 04:34 PM
GAVMAN
GAVMAN's Avatar
Default Location
I am in Hamilton, New Zealand.
You are right it is a strange one. I am a bit puzzled. I am going to double check the car that we compared it to then make a decision. We have a speedo shop here in Hams so my next step will be there.
Old 08-09-2004, 10:49 PM
Zero10
Zero10's Avatar
I have exactly the same problem, and I can verify another 944 owner with the same problem.
On mine the odometer reads correctly, but the speedo is almost exactly 10% optimistic over the entire range. It's not the sending unit in the transmission, since that would cause the odometer to be out as well. My odometer is about 2-3% optimistic, but I think that's because my tires are slightly worn. I as well have correct sized tires on it.
It seems to be common to all the 944's.
Old 08-10-2004, 03:39 AM
GAVMAN
GAVMAN's Avatar
Thanks for your reply. It appears I may not be alone on this one. With a bit of luck someone who has fixed the problem by recalibrating the speedo will see this. In the mean time I will ask a few people around here and will let you know if I find a solution.
Old 08-12-2004, 03:46 AM
Zero10
Zero10's Avatar
I am having my speedo/odometer checked next week, I'll keep you guys posted on the results.
From what I hear, Hollywood Speedometer is one of the few places that is authorized to repair VDO instruments, but that's quite the distance to ship your speedometer, it's too far for me as well. If I at least knew how optimistic it was for certain, I could just adapt my driving to compensate.
Old 08-12-2004, 06:35 AM
GAVMAN
GAVMAN's Avatar
Default Thanks very much
Keep me posted. Yeh! hollywood is a bit of a haul from here....
Quick Reply: 944 speedo problem
