944 & 944S Forum 1982-1991
MPG guage????
Old 07-24-2004, 03:01 PM
Moook
Moook's Avatar
Default MPG guage????
Hi folks .
Does any of you 944 people have a MPG gauge fitted in there car???
It will be in the rev counter ...
If so what models + years was this fitted??
+ are they reasonably acurate?????
Ta
Dave W.
Old 07-24-2004, 03:47 PM
944Ecology
944Ecology's Avatar
They are reasonably accurate... if you drive at steady state speeds with moderate throttle control, the numbers that you see on the gauge are fairly close.
The gauges were available on most (actually, I think, all, but haven't seen all of them) of the 8 valve
normally aspirated cars. The turbo uses that space for the boost gauge and the 16 valve cars have no gauge there.
gb
Old 08-21-2004, 08:26 PM
RSchuh
RSchuh's Avatar
my 83' 944 has the MPG gague
Old 01-17-2010, 12:04 AM
hp18racer
hp18racer's Avatar
Anyone know what inputs it uses? Is it really just a vacuum gague?
Old 08-31-2013, 11:03 PM
Shawns 83 944
Shawns 83 944's Avatar
I know this is an old topic, but during my search for information I saw this. I have the MPG guage that is not functioning. I thought it would be a vacuum operated guage, but it does not have a vacuum hose routed to the instrument. I will follow up with what I find later. If I in fact find anything.
Old 09-04-2013, 11:09 PM
bordin34
bordin34's Avatar
The gauge is based off the speed the car is traveling and the signal being sent to the injectors.
Old 10-04-2013, 12:36 PM
william_b_noble
william_b_noble's Avatar
the gauge is driven by the computer, there are no vacuum or mechanical lines to the gauge cluster on the later ones.
Old 10-04-2013, 11:24 PM
BimPorDoug
BimPorDoug's Avatar
The computer takes inputs from engine speed and road speed among other things. It needs the signal off the back of the speedometer. Without it the gauge reads VERY low and is off by probably 50%. If the upshift light doesn't work and the gauge reads too low, the hall sensor on the back of the speedometer is no longer providing data to the DME computer.
Old 11-25-2013, 07:45 AM
rubico
rubico's Avatar
When talking about the early 944, the fuel consumption is directly calculated in the speedometer. It gets the injection signal from the DME, the speed from the odometer by a pair of shielded cable plus the RPM from the speedometer itself. The output is produced by a very simple analogue circuit and is damped mechanically inside the display.
Quick Reply: MPG guage????
