Engine difference 84 - 85+
I'm looking to replace the block in my 944 Turbo and am considering using a 944 NA block and crank as these are the same blocks as the Turbo. I saw somewhere that a person was recommending using a 85.5+ block for my purposes. Can anyone tell me if there is a difference in block and crank between 84 and 85.5?
Scott
Scott
Hates Family Guy
The only difference I'm aware of is the hole for the temp sensor for the gauge on the dash. The later one is bigger, if you have an early block you can drill and tap it for the later sensor.
but what about turbo oil feed?
