Broken Pintle Caps - replacement?
After pulling the fuel rail to take out my bad FPR, I see that some of the pintle caps on the injectors are cracked and some are broken...
Can I buy new pintle caps anywhere? Or should I find a set of used injectors?
Thanks,
Colin
Thanks,
Colin
You can order the whole injector O ring kit, it will come with 3 o rings and the pintle caps. I think you can even get them at napa. All 4 injectors should cost you like 12-15 bucks. Oh when you go to put them on, rub some ATF on the injector tips to make the caps slide on easy, otherwise you can bust the new caps while trying to put them on.
