83 944 n/a Brake lines
I've got an 83 944 that is in desperate need of new brake lines (they are still intact, but they have seen much, much better days). Factory lines are a bit pricey, so I was wondering if anyone has had any luck finding comparable aftermarket lines or a good stainless steel line supplier?
Also, If I was looking for a source from which to obtain Factory manuals
(I can not find them anywhere and the last cd I purchased was garbage) where would I go?
bigdaddy@jasonmould.com
You can find a pretty good deal on dot stainless steel braided brake lines for about $65 from Paragon Products.
There are several good cd's of the factory service manuals, but, if you really want to spend the $270, you should check with your local Porsche dealer. They may no longer be available, but your parts counter jockey should be able to tell you that.
gb
gb
Thank you for the reply!
The local dealer has not had luck getting the manuals for a while, I just do not want to get screwed on another pirated cd.
I definately need to update with the paragon SS lines, do you have any suggestions for all of the steel lines?
Thanks again!
Thanks again!
