Can't get the hatch to stay closed
3rd Gear
Have an 86 944 Great Car....BUT....The rear hatch will not stay locked in place....Tried moving the locking enclosures (?) around....to no avail...Any suggestions....Before I sell her.....Thanks
Make sure that the latches are closing all the way... Some have gotten grungy and sticky in the last 18 years.
Also, make sure that the pin (which looks like an arrow pointing down) is not worn out. After a while the flat surface becomes rounded and it allows the hatch to pop up.
Good luck....
Good luck....
Jimmy D,
The pin closures, ( part on the body that the hatch pin goes into) should be a little loose, if the bolts holding it on are to tight then it can't align it self when closed.
