Wiring Problem on 1985 944
I am working on a 1985 944. When I received the car from the owner nothing worked on it. I went and checked all the fused and only a few were getting power. I pulled the fuse box out to see if I could see anything. When I pulled the fused box out I noticed that the plugs that plug into the bottom of the fuse box were not tight. If you press on the plug you can get everything in the car to work but when you release the pressure everything goes dead. I was wondering if anyone had any ideas on how to fix this problem. I need to get this problem fixed pretty soon so I can get everything else fixed. Thanks for the help
Scott Rogers
Scott Rogers
