Sensor broke in half
Lazer Beam Shooter
WELL THIS IS AN AWESOME CAR... I JUST LOVE HOW GERMANS DECIDE TO MAKE THIS! THE SPEED SENSOR DECIDED TO BREAK IN HALF WHEN I WAS TAKING IT OUT! I CANT EVEN REACH IT NOW ITS STUCK SO FAR DOWN THERE! SOMEBODY, PLEASE HELP! IM MAD THANK YOU!
Hope your planning on doing a clutch? Mine did the same thing, but the motor was out of the car then. After I took the bell housing off and clutch assembly I took a small screw driver and hit it from the top with some pressure, with time it worked its way loose. Good Luck with it!
