advice or recommendations on 944 T
I purchased an ’87 944 Turbo from a friend of a friend a week ago it is in need of some LOVE and rebuilding. The previous owner had the car up on blocks for the past 2 years in a garage collecting dust. He snapped the original driveshaft at the weak point. While he was waiting on the new one to arrive, he decided to rebuild the car and purchased these parts to replace on it.
With all of these parts, what other parts do you suggest? I have the stock clutch, but I plan on replacing it. We plan on using the car as a track car (road course), and as a daily driver on nice days. We would like to make 300 – 350 HP and 350 – 400 ft. lbs. torque. I understand that I will need a new mass air flow system, since the stock one is so restrictive, but I am not sure which one is the best to go with the parts I already have.
Do you think we should pull the engine to put the new rings and bearings in? We were told that it could be done in the car. Any advice or recommendations would be greatly appreciated, as I am a new 944 Porsche owner and we are striving to have this car perform close to that of our ’01 BMW M Roadster.
The following is a list of parts we already have:
Rising Rate Fuel Pressure Regulator
K&N Cone Filter Kit
Test Pipe/Down Pipe
Custom Exhaust
Auto Authority Stage 11 DME & KLR Chips
Glyco Complete Main Bearing Set
Auxiliary Shaft Belt
Auxiliary Belt Tensioner
Auxiliary Shaft Roller
Camshaft Belt Roller
Timing Belt Roller
Fuel Injector Seal Kit (4)
Bosch 7501 Spark Plus (4)
PVR Deluxe High Performance Brake Pads Brake Pad Set (2)
C.V. Joint Bolts (5)
Flywheel Bolt (9)
SARD Blow-off Valve
Rebuilt Water Pump (new)
Raceware Head Studs
ARP Rod Bolt Kit
Brake Line Hose
Front Tie Rods (2)
Timing Belt
D Ribbon Belt & 2 Other Belts
All New Circle Clamps
All New Hoses
Retaining Kit
Cam Ball Shaft Seal Kit
Clutch Alignment Tool
Retaining Ring Expander Tool
A/C Expansion Valve
Euro Hose Clamp
Distributor Rotor (3)
Distributor Cap
Magnacore KV85 Competition Spark Plug Wires
Ball Shaft Sprocket Holder Tool
Bushing Pre-Lube
Front Bushing
Piston Rings
Glyco Bearing Rod Set
Mechanical Fuel Pressure Gauge
Anti-Seize Compound Lube
Complete Head Gasket Set
Complete Block Gasket Set
Tranny with Cooler
Tranny with/out Cooler
Re-manufactured Driveshaft
MSD Ignition
Firebolt
Steering Wheel
MoMo Steering Wheel
18” Rims
Phone Dial Stock Rims
K&N Cone Filter Kit
Test Pipe/Down Pipe
Custom Exhaust
Timing Belt Roller
Flywheel Bolt (9)
SARD Blow-off Valve
Raceware Head Studs
ARP Rod Bolt Kit
Brake Line Hose
Front Tie Rods (2)
Timing Belt
All New Hoses
Retaining Kit
A/C Expansion Valve
Euro Hose Clamp
Distributor Cap
Bushing Pre-Lube
Front Bushing
Piston Rings
Tranny with Cooler
MSD Ignition
Firebolt
Steering Wheel
MoMo Steering Wheel
18” Rims
I would look at a Lindsey MAP kit, then you will more than likely need chips that match the MAP kit. New Tial wastegate, Bigger turbo would be on the list if you are looking for that much HP.
