Heater hose discontinued
Hi, Does anyone know where to get this heater hose for 1984 porsche 944 part# (94457238102) at, everywhere i looked it says it has been discontinued, Thanks
A long enough piece of heater hose that is the same inside diameter should work just fine. Might be 3/4 inch ID.
The hose has two bends in it and sets right behind the head,could not bend one enough without kinking it ,but thanks
The hose is not cheap, but might do what you want. |
ok thank ill check it out
take your old one to your local auto store to try and match up to a new one they have on the shelf.
i can't remember the application but there was a Ford model in the 80s that used almost an identical hose - the ORIGINAL heater hoses on my early '85 car had both Porsche part numbers and the Ford oval logo stamped in the rubber. i want to say a 1984 mustang 5.0. |
Good luck on removing the inside clamp up in the passenger footwell...I used a 1/4 in drive and a U-joint on about an 18" long extension to get to the clamp nut..might want to change out the water control valve at the same time. BTDT! no tee shirt..DANG!
I need a piece for the "#7" piece - anyone still have some extra to sell? Thanks!
