Strange 944 Running/ No Start Issues....
#301
#302
well I just spent the past few hours carefully reading thru this entire thread, what a roller coaster. I have recently bought a 1983 944 with the same symptoms you have been chasing. The car fires up with a misfire and blowing raw fuel smoke out of the pipe. The car will run for a few minutes until it dies, then will not start up. One day last week the car started up and cleared up and ran like a top for 10 minutes, then died SUDDENLY with no warning signs, then would not restart. the next day the car restarted with the smoke and misfire.
here is a list of things the previous owner replaced. temp sensor, crank sensor, j boot, air filter, cap rotor wires, plugs, injectors, dme relay.
I found that the car was over fueling to the point that the oil was full of fuel, to the point that oil was being sucked into the intake. i changed the oil and the fouled spark plugs, the fuel pressure regulator, cleaned out the air box. no change
I installed a fuel pressure gauge directly to the end of the fuel rail. I went thru the pressure and pressure leak down test on Clarks-Garage. all the values were dead on. I found a set of new re manufactured injectors hopeing that would solve the problem. I have checked the compression several times, the spark, checked for voltage at the injector connectors. I have swapped both the relays I have back and forth. the plugs keep fouling and the car continues to misfire and run rich.
What i will try next- the relay jumper- Check the positive terminals at the battery- unplug the AFM- unplug the coolant sensor- try the combination of the injectors plugged/unplugged. These are some of the quick things i can try before getting down to business. looking for a systematic approach to try to work thru this. I will inspect the dme relay and the ]ECU right away if you guys think i should start from there. I honestly dont know which way to go after reading thru this whole thread.
I hope one of you guys will take some interest and mercy on my situation like you did for Jake. I have decent troubleshooting abilities, as i have been fixing bikes and cars for 10 years. I have a garage set up with all the tools i should need to get thru this, hopefully with a little support. thanks guys.
944#447 (06-28-2023)
#303
Compression is great
Fuel pressure within spec? Great!
Check for 12v at the pump while cranking.
If you get the car running throw a meter on the pump and let it run and see if it dies. Isolate between an electrical issue or a mechanical issue. Yours sounds electrical to me but again don’t make any assumptions and keep testing!
Use clarks to test every single sensor in the engine or at least as many as you can. Look for correct voltages and continuity where it should be.
If you have fuel air spark AND all of your sensors check out and your fuel pump is not the issue, I would start the long arduous search for a reliable ECU. Keep in mind I had to go through like 3 of them and all the while I kept doubting myself.
Good luck!
#304
Like the AFM, the ECU is a circuit board printed in the 80s and in operation under heat & stress for thirty years. I mean, if you strapped an 80s calculator to the floorboard or the engine and drove 100k+ miles over three decades, would it still work?
I can't believe I'm still relying on my original ECU. It's nuts!
#305
My thoughts after sleeping on it
So if you guys disagree with my conclusions, please take them for face value. After reading thru this thread my thoughts are that Jacobs initial problems he was facing was a deteriorated injector driver circuit on his DME computer. His secondary problem he was facing was a intermittent DME Relay. As he went thru relentless troubleshooting, making adjustments here and there, and disturbing fragile connectors and wiring; he developed a set of issues beyond the initial set of problems. His car ran great for a period of time, and did not develope a cluster of issues simotaniously. His issue concerning the rich mixture and and misfire suddenly curred with a properly functioning DME computer, and his stalling/no start stymptoms cleared with a functioning DME Relay.
These things come to a head to me, and apply directly to my symptoms. My car ran great for the previous owner for years, and suddenly this issues appeared. It's also shows to be internment, as witnessed by myself. Many things were tested and replaced and tried over and over, with no positive move twords a solution.
It's also worth mentioning that the previous owner gave me a box of parts, including a DME computer that came from a verified good running car. I also have a new DME relay on the way. The P/O told me last night that he never got around to installing the DME computer because he was never lead to believe that it could be the root of his problems.
So at this point, before I go any further disturbing my system, which still will start and run every time I let it rest, should my next move be to install this computer and relay?
#306
I forget if yours is early or late but regardless disconnecting ECU/DME always makes me weary of that old stiff loom of wires I'm moving.
However, when you see how microscopic lines and cracks in the solder joints can disable the unit, as happened to me, you realize that even moving the ECU around--bumping it hear or there--might cause an issue with it
#307
Okay I follow what your saying. It may be worthwhile for me to do thorough inspection of my secondary ECU before installation. I'm handy with an iron and have reflowed solder joints on many PCB boards for audio equipment and other circuit boards. I have my first gets crossed at this point. If I don't get the results in hoping for a will begin from square one with testing sensors and continuity and the other finer points
#308
Swapped the DME
Hey I wanted to let you guys know I swapped the DME and the car ran flawlessly. I was able to drive it around for the first time. The car began smoking a bit after a couple laps around my shop, I didn't have time to investigate. I'll fill you guys in with more info later. Thanks
Jacob AbuKhader (06-24-2020)
#309
Again I’m terribly sorry for the insanely late response. Normally I get an email about replies to this thread.
#310
Hey everyone. This was a heavy thread and for those who might still be experiencing issues and using this as a guide I figured I’d periodically update this particular thread for those wondering if this was actually the solution.
The short answer, is yes, the long answer is I’m still not out of the woods.
My original issue was a sporadic and random case of failure to start. In failing to start the car would flood. (Dump excess fuel into the cylinders and fail to ignite). When the car would start, it would run horribly rich with CO levels reading off the charts.
By Installing a new DME unit, these issues were solved entirely. After getting the car in for emissions testing (as my registration is due this month) I’m happy to report that CO levels have returned to normal and I have been able to daily my car again for the last 3 or so months. So yes, the original issue of stalling and flooding was solved by replacing the DME. Credit goes to all those who sent in input on here as well as explained invaluable diagnostic procedures.
#311
Well I found a good article that explains how the DME relay works and how to correctly jumper. If this article is correct then I didn’t connect the right terminals. I connected terminal 30, not 86. Which explains why the fuel pump came on, but the car did not fire.
Gonna take out the coolant temp sensor and test it right now.
Ill be pissed if that DME is in fact bad.
By the way speaking to that fuel pump fuse anomaly. With the new DME installed, that doesn’t happen any more. It cranks but doesn’t start. Put the fuse in and the car starts. Swapped the DMEs, car starts and runs without a fuel pump fuse with the old DME installed.
Now with the new DME the only way to get the car to idle is if the coolant temperature sensor is unplugged. It’s like the car won’t run unless it’s on full rich, and then it dies shortly after.
Heres the article I found.
I only connected the fuel pump part of the circuit. Not the DME part.
it’s so over fueled that when you pull the pump fuse there is enough fuel in the plenum to keep it running. That’s where im at.
I’ve cleaned or replaced the entire fuel system had the injectors cleaned and flow rated. It’s low mile and well maintained. I have all the receipts.
I can’t figure out why it’s flooding itself out. The only thing I can guess is a bad DME.
looks like that seems to be the common issue
944#447 (06-30-2023)
#313
I’m having what looks to be a dying DME issue. I can explain the pull the fuse and it runs though…
your issue could well be the FPV fuel pressure relief valve on the fuel rail.
Pull the vacuum hose off the FPV and check to see if its leaking fuel into the vacuum system
If it isn't then check your fuel pressure and do a leakdown test to test the FPV is holding the correct fuel pressure
#314
quote Emergency Repairs
- If you suspect the DME relay is bad and you need to move the car, you may install do so by installing an "emergency" jumper across terminals 30, 87, and 87b on the relay / fuse panel. Some folks will tell you to jumper terminals 86, 87, and 87b instead. This allows you to only run the fuel pump, DME, and injectors when the ignition switch is turned on. Seems like a great idea on the surface. However, realize that the wire supplying power from the ignition switch to terminal 86 on the DME relay is a 1.0 mm wire and is only intended to carry enough current to pickup the primary coil on the relay. The wire connected to terminal 30 is a 4.0 mm wire which is designed to carry full current demanded by the fuel pump, DME, and fuel injectors. I strongly recommend using terminal 30 instead of terminal 86 to supply power via the jumper.
#315
Heres the link for Clarks instructions on DME relay bypass
http://www.clarks-garage.com/shop-manual/fuel-05.htm
Agree on doing a fuel pressure test. This is a must if you truly want to diagnose the issues. You need to determine if the FPR is good and what your pressure is before moving to suspecting the DME.
peanut (06-29-2023)
