Strange 944 Running/ No Start Issues....
#211
#212
thats really weird .....
If there is 12v+ on terminal 86 and the car runs.......... but won't run with the 12v+ on terminal 30 ???wtf its the same 12v+ from both terminals
is there any chance you could get a clear image of the DME relay base and surrounding fuse/relay box perhaps with a torch or lamp maybe
#215
Welcome to the struggle I have been dealing with in trying to diagnose this car hahahahahahahahahahahahahahaha.
Everything works the way it’s supposed to, except it doesn’t work anyway the way it’s supposed to.
#216
crazy !... its got me beat for the moment but its late and I'm tired maybe I'll figure out something tomorrow . if you can manage a piccy it would be very helpful as I have only owned later cars so i'm unfamiliar with the early fuse/relay boxes
#217
I'm taking bets. Odds:
Vacuum Leak - 1000 to 1
DME - 50 to 1
Ignition Switch - 2 to 1
The wire that PO ran for the dash mini-fan he had installed to replace the broken AC: Par
DME - 50 to 1
#218
I did my best to squeeze in there.
#219
well the engine runs faultlessly according to Jacob so I'd say the issue has to be a wiring configuration or connection issue which could be caused by the ECU especially as they have both been altered or modified .
#220
#221
If jumping 30 & both 87s doesn't start the car, I can't see what the relay will do different. What's interesting is I understand you have tach bounce connecting 86 but not connecting 30. Why would the reference sensor signal(s) disappear when there's a constant draw through 30 but not disappear when switched through 86?
#222
#223
#224
its not a signal its just a plain old 12v+ supply .They are identical The only difference between them is that T30 is live all the time and T86 is only live when the ignition is switched on
#225
Maybe connect with 30 and check reference signal(s) at the harness with an LED, harness both unplugged from DME and plugged in (from behind, harness cover removed)
