944S 1987 Turn ,hazard lights issue
Hello Guys,
I have bought a 944S 1987 a few weeks ago and i have finally got some time to start working on it.
I am dealing with a turn signal/hazard lights issue.
1.When the hazard light is pressed only the left lights(both front and rear) work,and the green light inside the dash is blinking normally
2.When I signal left or right ,they sometimes work ,sometimes they dont. When they work the green light is blinking solid green when they dont its fades until is completely gone.
3.The good thing is that all lights function whenever the green light on does is solid.
4.I changed the relay switch G4 but did nt make any difference.
Do you guys have any ideas what might be the issue?
Thanks in advance.
Thanks in advance.
Hello Danny and thanks for your reply.
Where can i find the grounds? Why do you think it might be a (power at the lights) issue ,when the lights do light up normally from time to time?
