No Start / Maybe the Ignition Switch?
Alright fellow 944 owners, today in a parking lot my 84 n/a decided not to start.
When I turned the key, the Dashboard came to life as usual, but the car DID NOT CRANK. (there was no movement, it was as it the car was dead, BUT all of my Dash "Check Lights" lit up as normal as I turned the key on the first click).
After doing much reading, it seems to be either;
(a) the Ignition Switch (the key has, in the past, on occasion, felt like it was "hung-up" on something when I went to start it / difficulty in turning forward, however, I haven't experienced this issue in months),
OR.
(b) may a ground issue some place.
So, after the good people at Haggerty Insurance picked my car up on a flat-bed and dropped it off at my house, I decided to give the key one more try, AND IT STARTED-UP as if there was never any issue.
THIS tells me that I am a likely candidate to get stuck somewhere again if I don't sort-out the problem.
Any suggestions? Would a bad Ignition Switch translate to Zero power to the Starter? OR do you you think it could be a Starter Ground?
Any specifics on what to look for first?
OR.
No start
OR.
OR.
