The larger sway bars of the later cars might have rubbing issues when used with the early control arms. I mentioned this because I replaced my original sway bar with a 24mm sway bar and the clearance between the arm and sway bar is pretty close. So you may need a little finagling. I believe 944Online used to sell a kit with the steel arms and all the related parts for this conversation.
