FS: Koni Double Adjustable Front/Rear Coilover Shocks with Ride Height Adjustment
Have available used, Koni double adjustable front shocks inserted into 951 modified struts for early steering knuckles , easy to modify if you have late spindles, instaing a 1 mm shim on each side of the flange and modifying the center to center bolt distance. The units are thread for full coilover height adjustment. They fit 83 -86 944's and front strut housings needs the shim for late spind!e, The rear shock mount requires aluminum trailing arms and Racers Edge trailing arm bolt assembly.
Also used Koni 3012 double adjustable rear shocks that have the parts to be coiliver.
Also have 2-8 lnch length 400 lb/in front coilover springs.
The parts are 3 years old in good condition and seen 15 track days. Consider selling front and rear shock assemblies separately
Package cost is $1800. Paragon price for the package is about $3500. Shipping is extra
Can post photos in couple of days because removing shocks now
