hi, few question about 944 s2 3.0L
hi guys i get me self me dream car white 944 s2 with 3L engine from 1989. But have loads to do... already changed a can chain and sliders, belts and rollers on timing belt and balancing shaft as well as water pump. Still have few stuff to change and here a question can you guys recomend were to get those parts oem or replacment ones and why to change them in best way? here is a list of the stuff what need to do:
1.clutch change(already have all parts i think-clutch,engine side bearing, engine seal,and pilot bearings)-what grease use for shafts and realese pivot bearings and shaft next to clutch?
2. gearbox oil change- whats the best one for that car?
3.need to replace cv joints rubber as thay have small cracks(im questing are bit old) best to chenge rubbers or complete cv joints as well?
4. rear shocks are weak so will need to replace them do you guys know were can get cheap ones or if can fix one from other car as for porsche are 130+ per one and for anader cars around 40+...
5.power steering pump work like it dont want to xD is it any replacment for them? i think some old bmw use same one or its just me?
Thanks very much for all the help.
Here's a few to get you started.
New parts:
1. Pelican https://www.pelicanparts.com/Porsche/index-SC.htm
2. Paragon Products https://www.paragon-products.com/
3. Sunset Porsche https://www.sunsetporscheparts.com/
4. Sonnen Porsche https://www.sonnenporscheoemparts.com/
5. Rock Auto https://www.rockauto.com/
6. Zims https://www.allzim.com/index.html
Used parts:
7. Plyhammer Parts https://plyhammersparts.com/
8. Just Joshin http://www.porsche944usedparts.com/
New parts:
Used parts:
two Ebay sellers for used parts I would recommend
1) 944reanimation
2) Larts_Porsche_Parts
Best of luck on your new project!
1) 944reanimation
and THAT is pretty much the best google search results you're going to get!
also: www.autoatlanta.com, www.944online.com
Parts Heaven - http://www.partsheaven.com/ Porsche salvage company that sells lots of new and used parts.
