944 & 944S Forum 1982-1991
944 2V power
Old 06-13-2018, 05:03 PM
michaelmount123
michaelmount123's Avatar
Default 944 2V power
I ran across an old engine build file recently, and thought I'd share the results which I found pretty surprising. Here's the build:
Core was a stock and untouched 2.5 2V.
Block sleeved with 4" bores
JE 10.8:1 pistons to my spec
Stock cam
Stock intake and TB
951 injectors
Stock valve size, competition valve job
Optimised ports
Stock exhaust manifold
3.0 crank, race prepped
951 rods with Rod Mod
Stock ECU with tuned chip
Here are the results. Given the limited mods (no cam, no header, but with 3L stroke), I was pretty surprised to get a tad over 200HP on my engine dyno. It's a pretty good example of what the 2V engine can provide with mostly stock Porsche parts.
File Type: pdf
Old 06-14-2018, 03:14 PM
RM512
RM512's Avatar
Michael
What mods did you make to the rods and pistons to run the 3.0 crank?
Old 06-14-2018, 09:20 PM
V2Rocket
Rainman
V2Rocket's Avatar
having done a bit of dyno experimenting i can see the bump in displacement (2.8ish) and the HEAD WORK really waking the thing up. compression doesn't hurt either.
nice!
Old 06-15-2018, 01:24 PM
michaelmount123
Originally Posted by RM512
Michael
The crank is a drop-in, but pistons have to match the increased stroke (shorter compression height). The stock 951 rod (and probably any stock 944 rod) will hit the pan rail due to the longer stroke, so it has to be relieved for clearance. A custom rod will typically clear.
Old 06-16-2018, 12:43 PM
V2Rocket
Rainman
V2Rocket's Avatar
I bet if you had that engine on hand and modified the intake runners to be say 3.5" shorter, it'd make 215 or so.
Old 11-11-2018, 10:35 AM
joseph mitro
joseph mitro's Avatar
are you using aftermarket or stock ECU?
Old 11-11-2018, 06:22 PM
T&T Racing
T&T Racing's Avatar
Hi Michael,
Thank you for posting, impressive
Old 11-12-2018, 04:17 PM
michaelmount123
Stock Motronic ECU, custom chip tuned on the dyno.
Old 11-12-2018, 06:44 PM
T&T Racing
T&T Racing's Avatar
Hi Michael,
Vendor for the custom chip is who????
Thanks,
Tom
Old 11-13-2018, 08:54 PM
951and944S
951and944S's Avatar
If you have your wheels spinning, I have a DTA/Fast laptop tuneable ECU with 944 terminated harness. Crank trigger and wheel, 4x1 coil pack....
Never used.
I can't use in Spec 3.
T
Old 11-18-2018, 12:19 PM
michaelmount123
Originally Posted by T&T Racing
Hi Michael,
Thanks,
Tom
It was tuned in real time on the dyno and a chip created. John Behe at RPR Automotive created it. He can do the same for you on his chassis dyno:
http://rprautomotive.com
Quick Reply: 944 2V power
