Fuel Pressure Damper Failure
2nd Gear
I’m new to the 944 world. I bought a 1990 S2 a couple months ago. I believe the fuel pressure damper has failed. Removed the vacuum line and raw fuel poured out of the nipple. This has been causing me a lot of starting problems. I cannot seem to find a new replacement one. If you guys have any info or tips on replacing or deleting the damper it would be greatly appreciated.
2nd Gear
You might look at the links first, they're about 100 bucks.
Paragon seems to be out of them but Pelican lists them as available.
I suspect you could also order directly from a Porsche dealer for similar price.
Good luck.
Good luck.
