S2 16 valve ported rebuilt cylinder head fs:
This is a 3 liter 16 valve S2 head from a clean ca car no corrosion at all around the cylinders removed from a running car. Just recently tore the head down & cleaned up the intake and exhaust ports with a mild 120 grit sanding paper porting tool on dremel. I did not change the profile of the runners or bowls just removed casting and smoothed them out. Then I took to my machine shop with over 35 years of experience selby & sons machine in Santa Rosa ca and had them take min off the deck for straightness and complete valve job with new seals. Comes with paperwork and
Matching caps but does not include lifters or cams or tensioner.
It’s ready to run on a street car or race car should make at least 10hp over stock with smoothed out higher flow head. I have this exact head that I did same porting too on my S2 race car it has mild camshafts and exhaust in it and makes 218hp at the wheels pulls very hard from idle to 6500 rpms
$900 shipped conus pm if interested thanks
I have over $500 of work into this head not counting the price of a good S2 core the cam tensioner mounting is excellent I had the machine shop install new steel threads for years of trouble Free reliability the matching caps are included just not pictured as is the oil pressure check valve it’s cleaned and installed now as well this head is ready to bolt up with a mild gain in flow!! $900 shipped then sell your core for $400-$500 and wow that’s a deal
