944 & 944S Forum 1982-1991
1986 951 8x16 Rear Fuchs fit Rear of 1986 944NA ?
Old 02-14-2018, 05:48 PM
Brecktex
3rd Gear
Brecktex's Avatar
Default 1986 951 8x16 Rear Fuchs fit Rear of 1986 944NA ?
I'm interested in obtaining a set of original '86 951 7x16 and 8x16 Fuchs for my '86 944NA. The 951 Fuchs front and rear offset (23.3mm) seems to be equal to that of my 7x15 phone dials. Sounds good; however, I notice in the attached list of 944 wheel sizes from Rennlist that the wider, rear, 8x15 Fuch optional wheel for an '86 944NA had a 10.6mm offset. This raises my concern that an '86 951 rear hub is not located the same as for the same year 944NA. Can anyone with experience using '86 951 7x16 and 8x16 Fuchs on the same year (1986) 944NA provide some advice/guidance ?
Thanks,
Bill
P.S. - FWIW, I have also attached a Fuchs wheel size - Porsche P/N - offset chart, based more on 911 usage, but it may be instrumental.
Old 02-15-2018, 09:55 AM
intrepidagent
Former Vendor
intrepidagent's Avatar
Thanks,
Bill
I have a set of 86 951 Fuchs on my 85.5 NA and they bolt right on without any issues as they are both early offset.
Old 02-15-2018, 10:05 AM
snb13
snb13's Avatar
They fit, they just stick out a little further (13 mm).
Old 02-15-2018, 11:20 AM
intrepidagent
Former Vendor
Here's a Black & White version of the chart you attached:
Quick Reply: 1986 951 8x16 Rear Fuchs fit Rear of 1986 944NA ?
