Interest in 3D printed spark wire holders?
I'm having a friend 3D print the two fuel rail mounted plastic spark wire holders and the one on the front cam housing. I wanted to gage people's interest in buying these for less than you can find on pelican parts.
I'd be interested in a set.
Mostly seeing how much interest there is (which determines cost via quantity).
It'll be ABS plastic I believe, and I'll test it out before I sell them, since I don't want to give anything that's going to fail.
As for wire size accommodations, it's going to be the exact same as the stock versions
Going to experiment with a couple different plastics actually, But we'd likely sell them as a set of 3 (the two on the fuel rail and the one on the cam housing). Probably around $15 for a set of 3 or $5 each.
$15 for a single piece from pelican seemed absurd to me.
Can you you double shot molding where a legend in white is embedded in black body?
Something great would be replacement buttons for the heater/air conditioning control unit.
