83 Porsche 944 knock!?!?! HELP
hey guys so i just bought this 1983 porsche 944 from a guy for a cheap $500 it had very milky oil but other than that no problems. so i knew the oil had to be due to a bad head gasket, so i got a new head gasket and sent the head off to be machined after all that i put it back on and thought it would be all good to go (wrong). not only was there still milky oil after i put new oil and filter in but now it has a knock and i have no idea what is going on idk if its rod bearings, bent valves, or what else. and why after doing all that am i getting water in the oil still???? im so confused. now on a side note the oil filter housing which i know on the 944 has an oil cooler inside, has a big crack in it could that be why water is getting in the oil or is that irrelevant. can anyone help me?
Early 944s are notorious for oil coolers leaking coolant into the oil. More that likely that was your problem, not the head. Guessing you now have a rod bearing failure which is not too uncommon. You've done the head now you may have to rebuild the rest of the engine.
As above
That's really unfortunate. If your not fairly certain it's a bottom end knock or is not just caused by excessive coolant in the oil it may be worth changing the cooler and oil and trying to see if it goes away. Just in case you end up with another unnecessary job on your hands.
I have a cooler and housing in good condition, but in Australia, but get in touch if they are hard to locate or expensive locally.
Good luck
Good luck
