Old Fuel
Old Fuel
Got an 87 944 Automatic. Has sat for too long.
What's the best way to get the fuel out? Is dropping the tank necessary? Should I disconnect fuel rail and let the pump push it all out towards the front? Any instructional pages for this? I have no idea how to work on Porsche but am ready to dive in. Thanks for any help.
Is the fuel varnished or just old enough to run poorly? On my car, that I recently revived after 15 years off the road, I siphoned as much fuel as I could out of the tank then filled the tank with premium fuel. I also disconnected the fuel line in the engine compartment routed the supply line into a small fuel container and cranked the engine to clear the old fuel out of the lines. It goes without saying...but I will say it, be very careful with any disconnected fuel line in the engine compartment. A new fuel filter is also highly recommended. The old fuel, which did not smell of varnish, was dumped into my wifes truck which already had over half a tank of fuel in it. Her truck ran fine with the old fuel diluted by the fresh fuel in the tank.
How long it sat is unknown, but the original owner said he checked the fuel and it's really dark colored and like varnish...
If I drain the the tank and put new fuel in, can I then keep turning the key in ignition forward (not quite to start position) to engage the fuel pump and keep doing that over and over until it cycles the fuel through the lines and returns back to tank? Do these cars work that way?
Once that's done, you probably want to flush the brake fluid and replace with new fluid. Check tire condition and if good, make sure the pressures are correct.
From there, you can try to start the engine, paying close attention to any fuel leaks and keep a close watch on oil pressure. I would let the engine run for 10 seconds before shutting it down to look for leaks. Then another minute. You want to make sure there plenty of Coolant in the system.
From there, you want to drive the car and get it up to operating temperature for a good 30-40 mins total, keeping an eye on gauges. If all is good, you can dump a full bottle of Techron or equivalent (bg44k) fuel treatment and then make sure to excercise the engine well. Full RPM redline runs in 2nd or 3rd gear on an empty highway, maybe 4-5 of them, should help blow some carbon and debris out of the engine, but remeber to only do this after the engine has been fully up to temperature 10-15 mins of driving).
I would also highly recommend changing the timing and balance belts and rollers before starting the car. While you are in there you should change the water pump too. You don't want a timing belt failure or it will cost you large sums of money to correct bent or broken valves, pistons, connecting rods, etc.
