Window Weatherstripping
I have a 1987 944S. I just replaced the window slot seals (lower horizontal seal) on each side. However the vertical piece of weatherstripping (at rear edge of window directly above door handle) needs replacing. The red leader in the photo points to the piece. Can anyone share the part number or link to where I can purchase this piece? I need one for each door window.
Attachment 1248253
Attachment 1248253
I just had a quick look on Pelican Parts for you but couldn't see that particular seal.
http://www.pelicanparts.com/catalog/..._pg2.htm#item4
I'm keen to find the part number too though as I have to do the same seal down the track.
I believe this is what you are looking for:
http://www.pelicanparts.com/More_Inf...537-079-00-OEM
It's called a window channel seal, it's in the PET under "power windows, window guide."
I just found the same part number at Sonnen for a little cheaper ($94 vs $121).
https://www.sonnenporscheoemparts.co...MzMwNCZyPTI%3D
