83 porshe 944 turns over. starting problem
i have a 1983 944 for 4years now.
the car wont start, have spark issues did a new tune up worked for a week im back to getting no spark again? i replaced fuel pump and coil a year ago. any solutions?
Not enough information provided to help you, Assuming you have good compression and you have fuel I would suspect DME relay or speed and reference sensors. If those check out then the ECU could be at fault.
