low beam fuse
looking for help...my '86 944 keeps blowing the driver's side low beam fuse. 7.5AMP, I believe. Put a new one in, head lamp works for a while, next day or so fuse is out again....not sure what is causing the fuse to keep blowing
passenger side no problems - high beams no problems. just driver's side low beam fuse. could it be a bad headlamp? |
Try putting a slightly larger fuse, 10 or 15 amp.
If there is an intermittent short in the wiring, it will blow the fuse. If it is just the headlight, then the fuse may hold up. You can get small shorts in the filament coils in a light bulb. If you do replace the headlight replace both, especially if they are old. The lighting will be better. You could also try swapping the headlight to see if the problem follows the headlight or stays in place. |
The wiring that flexes for the pop up headlight is a good place to look for a short.
I can't say that I never put larger fuse in a circuit myself, but it's really a bad idea especially on marginal European wiring. |
Originally Posted by marc abrams
(Post 14020424)
OP Update...I did go from 7.5 up to a 10 and haven't had any problems since albeit driving limited miles. Thanks fellas
