motor mount replacement time line
This Thread started out as asking if I really needed to replace my MM on my 85. It turns out it did. I also learned no one had a solid estimate of time; It was all over the board, 3 hours to 3 days. So here we go.... Using this document
http://members.rennlist.com/pirtle/svc_mm.html and these tools A 10 gal air compressor a 250ft# air impact a 19mm wremch a 17 mm wrench and the needed sockets 125# torque wrench 400# torque wrench the car is on jack stands about 14 inches |
if you dont know, just do them.
boy, is that the opposite of sex |
It's not that bad of a job. I'd do it just for peace of mind. The main difference I could tell was inside the cab. Before, some vibration was noticable. Now, smooth as silk after a year and a half on $15 Anchor mounts.
Open your hood.
Stand there looking at the engine. Have someone start the car. If the motor rocks, they are fine. If it does not move, time to replace them. Easy test for ya. |
I just got a really good look at them Up close. they are also dry rotted. Hell ill be done in no time. i am already on step 8
this will be a good time line. i am going to post between steps
9 done |
10 done, Im using an air impact
11 done
12-14 done
15,16,17 done
why 18? remove the air box?
done |
ah oh, need to go find something to lift the engine
19 im back and done
Kyle - hope you're taking good pics! Good luck with it...
