GT vs GTS 4R manifold
All,
I'm in the process of starting to build my GT engine. I have the cams and heads and had a question regarding the 4R manifold. In doing some research it seems that the heads and manifold were port matched to some degree.
I have the original 4R manifold as well as another 4R off a GTS. The GTS manifold is already cleaned and powder coated the correct silver whereas the GT manifold was powder coated a dark blue. My question is simply would I see any appreciable difference between the 2 4R manifolds?
There are no differences in part numbers or markings on the 2 manifolds that I can find so wasn't sure how much performance difference there would be between the two.
The GTS manifold allows me to start putting things together this weekend whereas the blue GT one will need to be stripped, powder coated and cleaned which will cause about a 3 week delay.
Appreciate the input.
Archive Gatekeeper
If you could measure a performance difference between two 4R manifolds I will buy a Rogerbox.
