New Steering rack Bushings = New car feel
UNREAL. i dont think i have been this jazzed about any repair or performance mod to data. a PITA Job, but well worth the fight.
these things practiclaly fell out on my head once i got the bolts out
new bushings installed and after a test drive, it feels like a completely different car! steering angles are probably 45 degrees better. CRAZY!!
Many thanks for the tips, DrBob and others. that allen head wrench trick to stop the tops of the hex bolts, was a deal saver. 2 of them were unreachable by the the box ends.
read for laguna seca with the new car!!
Hello Mark. I just did this to my 83 euro a month ago and car drives much better. I had an impact driver adopter with a hole in the ratchet end that I could drop over the nut and stick a 3mm allen into the hole to hold the adopter from turning while wrenching on the bolt.
I used the after market delrin replacements.
i could leave the rack on the car and work around all the obstructions. didnt even have to break out the power lines and tie raps.
was going to use aluminum, but the race is in 2 weeks I had one shot at this installation and couldnt take any chances with a delay the aluminums might cause.
Thanks to Mark at 928 intl for the quick delivery.
Archive Gatekeeper
What other PM do you have to do before the next race?
changed front pads and bled brakes , replaced rear rotors and amsoil oil change before last race.. checking the TB tension , as it was new before last two races..... wheel bearing needs to be tightened up on passenger side. other than that... i think thats it. oh, buying a new set of tires for Laguna (second set since 2001) my used sources have faded.................plus, its more fun on new tires and then the practice tires are better when they get demoted!
Mark - The thicker shoulder on the Delrin will lower the rack a bit. The upper half of the bushings causes the lowering, if my memory is correct. You should notice your steering wheel isn't level or has changed. Might want to check your alignment. I leveled mine by pulling the steering wheel and repositioning it. But to do it right one needs to pull the small black plug on the rack and look to see if the detent in the rack is centered over the hole. There's a special Porsche bolt (or you can make one) with a pointed end that goes into that hole and fits into the detent to hold the rack centered while an alignment is performed. Then the steering wheel can be positioned properly. On my to do list after I replace the shocks.
What I had to deal with until I put Carl's lower frame brace in was pretty much everything presenting itself to the steering wheel...a little too much steering feel for me.
I do love the difference the delrin's make on the directness though...
I take it your steering wheel now points in the same direction you are travelling- ha ha!
I am surprised you did not feel considerable "slop" in the steering response but I suppose when racing you are at one extreme or the other and not much inbetween - that and all pumped up with what is going on around you- quite an adrenaline rush I would think.
Rgds
Fred
Rgds
Fred
Developer
Mark - keep your eye on your Delrin bushings. Delrin will migrate under heat and high loads and the holes will become ovate.
Delrin probably good enough for some street driven 928's, but not a performance enthusiast and certainly not a track car.
You can see some elongation of the mounting holes of the Delrin bushings in these pictures as my customer was removing them to replace with our solid mounts. His is a street-driven 928, so this deformity occurred without a lot of side-loads like those in your car will see.
Carl
Carl
Carl
Carl
oh well, i got really good at doing it with the rack in place. removal would be a pretty easy task....... for a re-do.....
thanks for the heads up and i might be calling you for the replacements.
Mark
Rgds
Fred
Rgds
Fred
so yes, on the track, not much to notice.... but i have a feeling the handling is much worse, due to the amount of tire movement between the tires. the handling is not only more tight, but more crisp too. Ill see in a couple of weeks at lagunas race how much better it handles on the track.. with new tires too.
