New 928 Intake plan based on Aston Martin v8 Intake Manifold
#91
So admittedly I am very late to the party here, but is the stock intake really so restrictive that honing it out would give you a bump in air flow with less alternative engineering?
Edit - I am all for clever fabrication, just asking...
https://boneheadperformance.com/extr...-hone-pricing/
#92
Chronic Tool Dropper
Mark --
Standing by for your sketches/drawings with dimensions noted, showing the AM ports and spacing vs the 928 head ports and spacing. Look at the wall thicknesses of the AM casting to determine how much weld metal will need to be added and existing metal removed, and how you'll be able to make the transition from the AM metal to a connecting sleeve that will mate each AM port to fit into Hans' mounting flange nozzles.
You'll need to have a 928 engine block with heads mounted to get the spacings just right. Or have a sheet of aluminum (10+mm thick) waterjet cut to match the port configurations and bolt locations of the heads. the block will be a lot better as you progress, as you'll be able to include the water bridge and the oil neck.
Your next post should include these drawings, where the "dream" turns into a "design". Add schedule and budget, and you will have the beginnings of a "plan".
#93
#94
#96
Rainman
i think youll love this if you havent seen it before...
very relevant to the thread.
want a manifold for XXX rpm ?
plug and play...
http://www.superchevy.com/how-to/eng...runner-system/
plug and play...
There have been some interesting hints on the effects of proper runner lengths vs horsepower. I think Cheburetor in Europe noted that they saw a big improvement almost accidentally during a dyno tuning session on a modified engine, when they swapped in some longer BMW pipes. Would we see a reduction by the same amount if the ram tubes were completely eliminated? There's lots of work already around just the shape of the bell mouth and proximity to other adjacent flows; to the point where just a flat-floor intake even with the supercharger would not be good at all. The Threshie intake actually has a couple large plenums with fabricated runners to each port, so my analogy was poor. On supercharged engines, the air density change might support proportionally shorter runners, still much better than the pizza box "manifold" that many DIY setups seem to use due to space limitations. Think along the lines of better flow with less intake pressure, so less drive HP needed and less heat-of-compression to have to deal with. Separate discussion from Mark's project though.
#97
Extrude-honing has generated mixed results in the S4+ intakes. Better results, but very time consuming, have come from actual internal modifications to the stock S4+ castings. The original manifold is a compromise for space, and a lot of consideration given to driveability and a flat torque curve, rather than peak horsepower. Good cylinder filling at lower engine speed, in consideration for the auto gearboxes mostly, was particularly important as witnessed by the dual-path design with the flappy valve.
#98
Rainman
I'll sell you a pair of (aluminum) 944S2 intake manifolds if you want to cut them up and make a common plenum.
Runners are a little bigger than a 928S4 intake port and 14" long so you can cut them down to suit your target RPM range, the flange-end bolts onto a 928 head...just flip one end for end.
#99
thanks though!!
Dr bob, check out the S4 intake air path as it goes into the heads. its like a right angle to the head! (the middle cylinders. and the ends are not much bettter)
#100
yes, the stock intake is fantastic for those that really dont want be active with the gear box after all, the flappy gives the "flatter" torque curve and bump in the HP down low. however, if you drop a gear and dont mind the RPM revs, you get even more regardless of what is happening down low.
yes and for those that go WOT at 3000, the dual path design , so many street cars employ is a good design. I removed flappy long ago and never looked back, but i drive the car different than most. i never floor my car below 4500rpm, its pointless when you have a gear box to work with. however, driveability, is the main gain here. SO, the reason for the replacement for the S4 intake, is there really no racing need for lower torque or HP benefits if i can gain something up top and use the gears and the UPPER RPM to take advantage. After all, flat torque curve , means, " rising HP curve" .. I'll take a falling torque curve any day of the week for any given HP level!
#101
Ill need to access the lower intake manifolds........ do you think hans would share the drawings so i can make it , for a fee? otherwise, i have to wait until his next run , OR, i can always lap off the intakes bases of the 944 intakes.... heck that might even work out better.
AND, i either need a dummy S4 intake or the template i see others using as a jig.
thoughts about that?
#103
The choice of a 944 manifold flange as a "base" is always interesting, but there are some serious metallurgical considerations there around welding; better to have Hans make a set for you in an alloy that can be welded to your AM intake, whatever metal that is?.
[/quote]
Item 27: make a jig
And you don't really need a "dummy" S4 intake. You Need A Dummy S4 Block and Heads. Unless you want to duplicate the S4 intake, what good will a dummy version do for you? You'll want at least the block or the thick aluminum template to weld on. Welding aluminum involves some pretty serious expansion and contraction as the assembly heats and cools in odd directions, so holding it rigid and sinking some heat seems like a requirement. Maybe have the flanges made with enough extra thickness that it can be milled flat once all the welding and grinding are done. Talk to your welder to see how he feels about all this, along with the access issues he'll face trying to weld any of the inner connection faces.
Get back to us when you have a design. All this stuff in the meanwhile is smoke.
#105
We've shared plenty of hints and tips. Planning comes AFTER you have a design. Three things make a real Plan: Scope, Schedule, and Budget. Scope in this case equals a design. Then you get to look at your available budget and build a schedule based on scope (the plan), availability of talent (the welder/fabricator plus Hans' parts (really part of Scope), and budget. Mark, until you have those pieces, you have a Dream.
Why do you ask that question here? PM or call or e-mail Hans. He may loan you a set of 3D-printed prototypes, or give you the dimensions, maybe even a dimensioned sketch. He has shared the CAD images here previously, including links to a 3D viewer that lets you rotate the images. Question goes directly to Hans for any of that.
Add it to your list:
Item 27: make a jig
Item 27: make a jig
why cant i use a stock intake gasket?
