Radiator Cooling fan
While waiting to pass Canadian Customs - Coming back from Camp928 this week-end, I heard my radiator fan spinning at full speed. At home, I saw that only one was running (passenger side).
I checked the fuse and it was blowed. This is the second time that this happen - same thing last fall after Frenzy.
I saw the a new fan from Porsche is around 325$ (928.624.145.00)
Is it possible to rebuilt those fan?
Anyone tried those : http://www.v12s.com/porsche_cooling/porsche_928_cooling
Other options?
Other options?
If the fan does need replaced consider buying a new aluminum housing and Spal fan set from Hans SerVaas here on the forum. If memory serves his kit isn't much more than the price of one fan from Porsche.
Mike
Mike
No affiliation except for a satisfied customer.
Basic Site Sponsor
Basic Site Sponsor
Other options?
Other options?
Note that your car did not overheat when the fan quit. The other fan simply ran at a higher speed, which you mentally noted and checked when it was convenient (not sitting on the side of the road with a boiling engine.....or worse.)
The 928 cooling system is one of the things that makes the 928 such a remarkable vehicle. The electronics and logic circuits, combined with the two fans that can run at different speeds (when required) make overheating a virtual non-event. Re-inventing or re-engineering something for an incredibly functional and reliable system makes absolutely zero logical sense.
Do yourself a favor....order two new stock fans and install them as a pair. Make sure the amplifier works properly on both high and low speeds, when you install the new fans. Make sure all the inputs to the logic controller work and that the logic controller sends the proper signals to the amplifier.
Done.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Of course, some 928s do not have very sophisticated cooling fan systems with logic and variable speeds.
As a datapoint, the Hans fans can/do fit S3. I added a couple of mounting slots to clear some tabs on my lower core support, but it is basically bolt in.
