Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   928 Forum (https://rennlist.com/forums/928-forum-69/)
-   -   Door panel plastic clips positions (https://rennlist.com/forums/928-forum/994497-door-panel-plastic-clips-positions.html)
concor 06-10-2017 12:52 PM
3 Attachment(s)
Hi guys, so I have ordered the three types of door panel clips for my '84 928S euro door. However, the manual does not show where each one goes. Does anyone know what goes where? Is it already correct how it shows it on the photograph below?
433 867 299 A - white and longest (left)
823 867 299 - black (middle)
999 591 559 40 - see-through white and tiniest (right)
Attachment 1353816
Attachment 1353817
Attachment 1353818
ROG100 06-10-2017 01:24 PM
PET is confusing on this subject ----
999 591 559 40 is for the door card in the center of the panel. It says 6 but you only use 4 per car
823 867 299 x 22 per car
433 867 299A x 4 per car.
I have cars that have all white clips. I have seen mixtures of black and white.
The white clip allows some space between the panel and metal maybe to allow for the material.
The black clip pulls up hard - panel to metal.
Thats my 2cents worth interested to know what other theory's are.
87m491 01-28-2019 12:12 PM
Late to the thread but just pulling my door panels on my recently acquired 89 S4 to replace the door stop. My car has the 299A's all along the outer edge and bottom like the OP.
Seems to make sense to have the longest where the carpet folds over for the extra room mentioned. Mine are mangled beyond belief. I'm guessing either the
299a's or the black ones will work fine. Having been into a lot of these fiber board door cards from Porsche and Audis of the day, I have not seen one hold up as
well as on this 928. While more than half of the rivets are toast, each mounting hole in the fiber board is intact and not shredded. I thought I'd have to glass each over each
but they are fine even after extricating the crushed pins. Very impressed so far.
ltoolio 01-28-2019 12:53 PM
Good pic for the clip pictures:
http://classicnineleathershop.com/92...raw01clips.jpg
dr bob 01-28-2019 07:29 PM
The left clip in the above picture allows space for the carpet while maintaining alignment and support at the door card. Use them where there is carpet. The other two are functionally interchangeable. Except for the clip side length, once installed they do the same job.
UKKid35 01-30-2019 04:55 AM
Just curious, what is the cut-out next to the courtesy light for?
Geza 01-30-2019 07:53 AM
Coin holder for LHD models, I presume.
UKKid35 01-31-2019 05:13 PM
Many thanks - I had no idea they existed, or that they would be mounted upside down
https://rennlist.com/forums/928-foru...er-trivia.html
Christopher Zach 04-06-2019 07:45 PM
This is an interesting thread, I had all black ones on my door from the PO and it was a mess. Now all white ones and happier but I will try two black ones on the card insert by the door handle.
Moving around the car, is one supposed to use white or black ones on the top rear hatch cover (where the rear light is)? How about the top inside roof panel? Seems like the black ones that are in there are too short (and everything has been disturbed by PO running bad stereo wiring in the 80's or something).
Any official manuals?
Geza 04-07-2019 09:13 AM
When I took my right side door card off, which I believe was never messed with, it had 12 white (including the 2 on the leather insert) and 3 black. The black ones were (in the door card picture above) the 2 on the upper left and the 1 on the right (below the door lock cutout). I replaced mine just like this and it came together nicely.
blodstrupmoen 06-14-2019 03:20 AM
Do anyone have a good source for these clips ? Preferable in 50 or 100pcs .
There is a lot on ebay , but previous I bought where crap so thought I should ask here before giving it another go.
Christopher Zach 06-14-2019 09:37 AM
Any of the happy vendors/sponsors would carry them. Ebay is eh, and you *really* need the right combination of ones to do this job properly. Spend the extra couple of bucks and buy from a vendor.
blodstrupmoen 06-14-2019 02:06 PM
It is the same clips used on other Porsches , Audis and Bmws. Even my Lr uses some of the same clips.
1,5$ a clip. Well thats 300$ for 2 different sets a 100 and probably 80$ in shipping .
ROG100 06-14-2019 02:28 PM
There are only 26 clips used on each door so total 52.
White are $1.75 each and black $1.49 each.
On a Porsche 928 Supercar it does not get cheaper than that!!!
Buy cheap and they are crap - you get what you pay for.
Not all clips are equal.
Christopher Zach 06-14-2019 02:30 PM
Do what you do, however putting the wrong clips in the wrong holes makes problems, and I have bought clips on Ebay that were total garbage. So your mileage may vary.
