Coolant leak @ water bridge. Pretending to be Passenger head
Just need to vent for a minute. As some may know I've spent the winter re-sealing a 100k mile '88 engine I purchased from Gary Knox to replace my 230k lump that has seen better days. Finally got it started up yesterday and ran it today long enough to heat up the trans and top up the trans fluid and discovered the new passenger head gasket I installed is seeping coolant at the bottom front corner. I used new head bolts, made sure the washers didn't rotate as I tightened the oiled bolts per the WSM procedure of 20nm then two 90 degree rotations. I debated whether to use the old racers trick of letting the gaskets sit 30 minutes, then re-doing the torque procedure and decided that the engineers in Stuttgart were paid well to determine the correct torque procedure so I followed the WSM to a Tee. Frustrated that I'm not done with this saga cause the motor sounds great compared to my old lump and it is peak driving season here. Plus, I just love driving a 928. Debating whether to pull the engine back out and completely re-do that head gasket, do the head gasket with the engine in the car, or just drain the coolant and try re-doing the torque on the bolts. I'm not too concerned about the new bolts being over-stretched so that will save a couple hundred dollars (the 180mm bolts have doubled in price from $9.80/ea to over $18 /ea since I bought the set for this job.)
What say the group?
Mike (bummed in Arkansas)
Update: looks like the issue is with the powder coated water bridge leaking, not the head gasket.
What say the group?
Vegas, Baby!
I'd PM Greg Brown. He'll give ya the best advice, Mike.
Received 1,542 Likes
Let the engine cool. Put paper towels stuffed under the water bridge hoses.
Then pressurize the coolant system with a tester (rent one from AutoZone or Advanced Auto Parts, or NAPA, etc.)
Then check to see if your paper towels are wet or the head is actually leaking.
Thanks Dave. Already fixed a leaking rad hose by rotating the clamp so it could be tightened completely. I'll double check the rest to be sure.
Mike
Mike
Basic Site Sponsor
Basic Site Sponsor
What say the group?
What say the group?
Dripping off the side of the block just forward and below the protrusion for the locating dowel onto the compressor shield, then off the shield onto the back of the compressor. But, the car is on stands with the front a bit higher than the rear so gravity might be at work. I just stuffed the under-bridge area with towels and ran the engine until the fans cycled twice. Should have coolant pressure so we will see.
Thanks for talking me down off the ledge everyone.
Mike
Mike
Well, preliminary results are that there is a leak at the coolant bridge as after putting towels under that area and running the coolant up to temp I haven't had any drips so far. I re-used the bridge that came with the engine I got from Gary Knox and it has been powder coated. Hopefully the powder coat isn't too slick. I seem to remember others here that have had issues getting the hoses to seal to powder coated nozzles. At any rate, that will still be easier than dealing with a bum headgasket.
Mike
Mike
Mike
Mike
Basic Site Sponsor
Basic Site Sponsor
Mike
Mike
The most common problem is for the rear adapter for the heater to warp slightly. The other problem is that the adapter in 1988 was of the two piece design and could leak where the hose attachment piece is glued into the main body. Always replace this piece with the "updated" version 928 104 713 02. Combine this with the very soft Victor Reinz gasket under this....and 18 ft lbs of torque and the gasket will split. Additionally, ANY additional sealant applied to this gasket will make it "slip" and leak. The fluid runs forward along the trough where the head meets the block and runs down the front of the head surface.
Of course, the front water cross-over can also be a source of a leak....this is also a very tricky area to get to seal. Many people "powder coat" the water cross-over....this is generally a disaster! The hoses can't get a grip and blow off, the gasket surface is too uneven to seal where it attaches to the head. The temperature sender won't get a good ground....the list goes on and on. I shudder every time I get an engine in with this piece powder coated. I will not assemble an engine with this piece powder coated....I just throw it away and get another one.
There are very specific things that need to be done at these junctions, for them to not leak.....I've tired many different approaches before I found what reliably works.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Thanks for the insight Greg. I didn't skim the heads as none of the small pits were anywhere near the sealing areas (fire ring or gasket "bead" area.) I just scraped the head and block surfaces clean with a razor blade till everything was clean. I will drain off some coolant and swap the powder coated bridge for the original "bare" unit from my old engine as I suspect this is the source of all the problems.
Mike
Mike
Basic Site Sponsor
Basic Site Sponsor
Mike
Mike
Use the stock red silicone gaskets on the water crossover . Thin.layer of Drei Bond on the two flanges (including some on the red silicone), to help with any imperfections in the surfaces....no paper gaskets on this end.
I used the paper gaskets in my 81 ion the water bridge and it started leaking coolant again after 2 months. They were the VR gaskets.
At least this time the bolts wont pose a problem...
Basic Site Sponsor
Basic Site Sponsor
I used to install factory gaskets in addition to the red silicone seals, under the front crossover, before I figured out that Drei Bond worked better.
I generally use factory gaskets on the rear of the head, except in special circumstances.
BTW......Drei Bond on any paper gasket is, in general, a mistake.
On a personal note, I'm not very "fast" at what I/we do. We, very rarely, get anywhere near "flat rate" allowed job times. I/we think about the implications and potential problems with every single piece we use. Every single used piece we install is clean enough to lick and has been inspected for flaws or damage. Every single new piece has to perform as well or better than a factory new part, as installed 30 years ago.
There's no way around the fact that quality takes time. There's also no way around that doing something a second or third time sucks.
