odometer reset
odometer reset
Hello to all. I have a 1981 euro model and I just replaced the odometer gear that is a common issue. My question is where is the reset switch located on this car. The dash is missing some parts under the steering wheel but there are a couple push button switches that are broken. Thanks if anyone has the answer.
On my 81 it is the bottom left button switch - has a funky square symbol on it. The switch activates a solenoid in the odometer reset mechanism.
You can see it in the interior photo of this '82: https://rennlist.com/forums/showthre...ferrerid=68970
That info would be in the Owner's Manual for your car. If you don't have a copy see the FAQ sticky for links to digital versions.
On my Euro, lower left (pod) is REAR FOG LIGHT SWITCH a red coloured light symbol is illuminated when I depress it.
You can call me Otis
thanks, had already discovered that my '85 zzz vin us car had hidden wiring, now I know why, and have some ideas for how to make a 007 type device, or at least a stealth switch for the bleach squirter to the rears, so I can make white tire smoke like the SC cars.
