928 Forum 1978-1995
Sponsored by: 928 Specialists
Plastic (?) underbody shields under motor on 85 928S
Old 04-19-2017, 02:43 PM
2002M3Drew
2002M3Drew's Avatar
Default Plastic (?) underbody shields under motor on 85 928S
Hi all,
i think im missing an underbody stone shield or two under the front of my car. It's an 85 928S. Anyone know the part names/part numbers? I'm having a problem even searching for them. Thanks!
Drew
Old 04-19-2017, 02:59 PM
77tony
77tony's Avatar
http://www.porsche.com/usa/accessori...artscatalogue/
Old 04-19-2017, 03:14 PM
davek9
davek9's Avatar
There is only one metal (aluminum) shield that I know of, it goes under the radiator and stops just in front of the oil pan, helps w/ air flow and protects the belts from gathering up road trash.
FYI., they are hard to find especially in good shape.
Dave K
Old 04-19-2017, 03:22 PM
928NOOBIE
928NOOBIE's Avatar
My early '86 has the shield davek9 describes above. While mine is bent around it's still in fine shape and does it's job. The only thing with mine is occasionally it gets a little close to the AC compressor so I hear a little noise every now and then...the shield can be pulled a little by hand downward .
It's held on with speed nuts...so you do have to be careful during re-assembly...they wear out depending on how often the shield is removed thus need replacing periodically.
Old 04-19-2017, 03:25 PM
s4hounddog
s4hounddog's Avatar
I believe 928 Motorsports still offer an aluminum belly pan( under the motor) for around $350
Old 04-19-2017, 03:52 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Dave K
I've never seen anything other than what you've described either.
Old 04-19-2017, 04:33 PM
davek9
davek9's Avatar
That is for an S4, the S3 and earlier 16v does not have an under Engine belly pan.
Old 04-20-2017, 01:35 AM
Dave928S
Dave928S's Avatar
Here's a thread with some pics of what you need ... https://rennlist.com/forums/928-foru...elly-pans.html
Quick Reply: Plastic (?) underbody shields under motor on 85 928S
