Kevin and Kevin's Excellent Adventure Begins
Factory Specs for VIN Number WP0JB2929LS860468
1990 928 GT U.S. 0406
Production Number Country Order Code
Number 406 out of 455 produced for 1990 928 U.S. market. US 928950
Engine Info
Engine Code Engine Size Comp Ratio HP SAE Torque: ft-lbs FI System Qtr_mile: sec 0-62mph: sec Top Speed: MPH Weight
M28.47 5.0L-32v 10.0:1 326 317 LH-Jetronic 14.1 5.8 171 3505
Transmission Info
Transmission Code Transmission Serial Number Range Final Drive Ratio Notes
G28.55 5-speed Manual G28553L00001 to G28553L20000 2.73 Limited-Slip - PSD (M221) (Standard)
Options
Option Code Description No of 1990 cars with this Option No of '80-'95 cars with this Option
M418 Side Protection Moldings 1017 17506
M498 Without Vehicle "Type" Lettering on Rear End 516 4558
M570 Air Conditioner with Improved Efficiency (Rear A/C) 638 7191
M650 Electrical Sliding Roof 2520 38586
M691 CD=Player "CD-2" with Radio 199 852
Engine Info
Transmission Info
Options
Supercharged
The previous owner is a very knowledgable 928 person. I'm sure a quick call will clear it up. I spoke to him just yesterday. Sad to see him exiting the "928 life" but he'll always be a GREAT friend!
Congrats Kev's COA lists exterior and interior colors, options, etc., and would be a nice addition to this special GT. Super rare and cool color combo...subscribed. T https://www.pca.org/resource/porsche...e-authenticity
Thought I would provide an update and some pics on the GT. Have been making progress as we extracted the engine from the S4 and started disassembly so we could get the GT engine back together. The GT heads had been reconditioned and stored and are in excellent condition. Have installed the heads and cams, new IWIS racing chains and tensioner pads. Also got timing gears installed along with the rest of the front of the engine.
Right now am awaiting completion of powder coating on the manifold and cam covers and once I have those back will clean well and install. My hopes are to have her running and ready to head to 3rd Coast in November. Might not have body work complete but mechanically should be sound.
Also, have a torque tube with Constantine Super Bearing (Thanks Kevin_in_Atlanta!) and Hans new shifter to install when the time comes. Will be turning attention to the interior while I wait on the powder coated parts.
Latest picture of the GT engine almost ready to drop in. It now has ceramic coated manifolds.
There has been quite a bit of work done since my last post in August. As Kevin_in_Atlanta posted, the engine is about ready to install.
1.Have also installed stainless steel brake lines, had brake booster and master cylinder refurbished by White Post and bled system. New cross drilled rotors and pads.
2.New clutch master and slave with Greg Brown line.
3.Repacked CV joints with new boots.
4.Dropped the gas tank, removed the non-op internal pump and replaced with a strainer and the Bosch 044 external pump. All new rubber lines at the tank.
5.New suspension, Bilsteins and Eibachs springs.
6.New AC compressor with rebuilt barrier hoses.
Rebuilt oil line cooler lines.
7. New hood and hatch struts
8. Greg Brown fuel lines
9. New Ford 4 hole injectors
10. Hans shifter
11. Torque tube with Constantine bearings
Here are a few pics of the activities. Outside chance she will be at SITM otherwise it's the GTS.
10. Hans shifter
