928 Forum 1978-1995
Sponsored by: 928 Specialists
Kevin and Kevin's Excellent Adventure Begins
Old 04-10-2017, 10:51 AM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Factory Specs for VIN Number WP0JB2929LS860468
1990 928 GT U.S. 0406
Production Number Country Order Code
Number 406 out of 455 produced for 1990 928 U.S. market. US 928950
Engine Info
Engine Code Engine Size Comp Ratio HP SAE Torque: ft-lbs FI System Qtr_mile: sec 0-62mph: sec Top Speed: MPH Weight
M28.47 5.0L-32v 10.0:1 326 317 LH-Jetronic 14.1 5.8 171 3505
Transmission Info
Transmission Code Transmission Serial Number Range Final Drive Ratio Notes
G28.55 5-speed Manual G28553L00001 to G28553L20000 2.73 Limited-Slip - PSD (M221) (Standard)
Options
Option Code Description No of 1990 cars with this Option No of '80-'95 cars with this Option
M418 Side Protection Moldings 1017 17506
M498 Without Vehicle "Type" Lettering on Rear End 516 4558
M570 Air Conditioner with Improved Efficiency (Rear A/C) 638 7191
M650 Electrical Sliding Roof 2520 38586
M691 CD=Player "CD-2" with Radio 199 852
Old 04-10-2017, 01:32 PM
kmascotto
kmascotto's Avatar
Nice save! now to work
Old 04-10-2017, 03:08 PM
Tom in Austin
Tom in Austin's Avatar
Great find, look forward to many pics of the restoration! Interior looks a lot like 'Mahogony brown' from the late 80s, have you located the code to verify what it is?
Old 04-10-2017, 03:24 PM
Kevin in Atlanta
No we haven't. Where would we find the code?
Old 04-11-2017, 02:42 PM
AO
Supercharged
AO's Avatar
The previous owner is a very knowledgable 928 person. I'm sure a quick call will clear it up. I spoke to him just yesterday. Sad to see him exiting the "928 life" but he'll always be a GREAT friend!
Old 04-11-2017, 03:23 PM
77tony
77tony's Avatar
Congrats Kev's COA lists exterior and interior colors, options, etc., and would be a nice addition to this special GT. Super rare and cool color combo...subscribed. T https://www.pca.org/resource/porsche...e-authenticity
Old 04-11-2017, 04:08 PM
Tom in Austin
Here are some interior codes I found a while back, maybe matches up to the sticker on the jamb?
Old 04-11-2017, 04:55 PM
bubba928
bubba928's Avatar
Ditto re the above comments. Another GT to be brought back to life. Great news and good luck!
Old 08-31-2017, 11:44 PM
jetson8859
jetson8859's Avatar
Thought I would provide an update and some pics on the GT. Have been making progress as we extracted the engine from the S4 and started disassembly so we could get the GT engine back together. The GT heads had been reconditioned and stored and are in excellent condition. Have installed the heads and cams, new IWIS racing chains and tensioner pads. Also got timing gears installed along with the rest of the front of the engine.
Right now am awaiting completion of powder coating on the manifold and cam covers and once I have those back will clean well and install. My hopes are to have her running and ready to head to 3rd Coast in November. Might not have body work complete but mechanically should be sound.
Also, have a torque tube with Constantine Super Bearing (Thanks Kevin_in_Atlanta!) and Hans new shifter to install when the time comes. Will be turning attention to the interior while I wait on the powder coated parts.
Old 09-05-2017, 08:44 AM
richvm
richvm's Avatar
Kevin,
I have D90s with TPS. Call me if you need them,
Rich
Old 09-05-2017, 10:42 PM
AirtekHVAC
AirtekHVAC's Avatar
Sweet car. Great thread.
Old 03-25-2018, 11:50 AM
Kevin in Atlanta
Latest picture of the GT engine almost ready to drop in. It now has ceramic coated manifolds.
Old 03-25-2018, 10:52 PM
jetson8859
jetson8859's Avatar
There has been quite a bit of work done since my last post in August. As Kevin_in_Atlanta posted, the engine is about ready to install.
1.Have also installed stainless steel brake lines, had brake booster and master cylinder refurbished by White Post and bled system. New cross drilled rotors and pads.
2.New clutch master and slave with Greg Brown line.
3.Repacked CV joints with new boots.
4.Dropped the gas tank, removed the non-op internal pump and replaced with a strainer and the Bosch 044 external pump. All new rubber lines at the tank.
5.New suspension, Bilsteins and Eibachs springs.
6.New AC compressor with rebuilt barrier hoses.
Rebuilt oil line cooler lines.
7. New hood and hatch struts
8. Greg Brown fuel lines
9. New Ford 4 hole injectors
10. Hans shifter
11. Torque tube with Constantine bearings
Here are a few pics of the activities. Outside chance she will be at SITM otherwise it's the GTS.
Old 03-26-2018, 12:20 AM
Mark R.
Mark R.'s Avatar
Hey Kev, Things are looking pretty good. Nice progress being made.
What color is that powder coat on the intake manifold and cam covers..?
Old 03-26-2018, 10:03 AM
jetson8859
jetson8859's Avatar
Mark,
its silver with a black vein. Here is a little closer picture. I think it goes well with the slate grey metallic exterior.
Quick Reply: Kevin and Kevin's Excellent Adventure Begins
