AC bypass
AC bypass
I bought a 1982 Porsche 928, I would like to remove the AC compressor, is there a bypass pulley available or can I just remove it considering it has an independent belt?
Just make one. Take a bit of work but you could fabricate one. Be easier to leave it.
Team Owner
As others have also mentioned,
if you look at the way the belts are positioned,
they offer a side load to the crank snout,
IOW the loading is pretty even to cancel each other out.
NOTE with the air pump and AC compressor removed,
then the pull will come from one side.
if your belts are really tight this can side load the crank snout,
and transfer into the front main bearing.
Take apart a girdle and look at the front main bearing to see how it wears from lack of belts, or tight belts
The smog pump is on the left which I need for emissions inspection and the alternator and power steering are on the right, of the four wouldn't the A/C be the most taxing. It is possible that serious stress on a crank can cause premature wear on front bearings. I am a 87 GN guy, 1st Porsche project and liking it, thanks for the info!
So the more or less constant downward force of the running engine is of no concern, but the load from the accessories on just the one side will most certainly overcome the shear factor on the bearings, got it!
Just so I am understanding you on this,
Because it is counterweighted and balanced means that it does not exert any downward pressure, even when parked?
Or how about the multitude of SC cars who have a much larger belt, with a much higher tension than any of our stock accessories run? Because of this, how many miles should SCed cars go before they tear down and install new front mains? Are you going to be replacing yours before you install Hans's SC setup?
The reality is that no one has any definitive proof that running accessories off one side of the crank causes any damage to the bearings on our engines. In fact all the newer single serpentine engines have pull from only one direction. There is no issues with them....
You will see much more damage to the bearings if you run garbage oil, don't change your oil often enough, track your car, the list goes on.
There are numerous people on here, myself included who have run 928 engines for long periods of time without the AC or smog pump belts on. None of us have seen any adverse side effects. I pulled one engine apart that I had done this with for probably 5+ years. There was zero abnormal wear from other engines that I have disassembled.
