928 Forum 1978-1995
Sponsored by: 928 Specialists
instrument cluster lights out - Ashtray light still working
Old 04-13-2017, 09:30 PM
Captain_Slow
Captain_Slow's Avatar
Thanks Ed. The condition is surprising. My car is very clean and there isn't a source of moisture, etc. It's puzzling. I sprayed it with cleaner this morning and will apply some Deoxit 100 tonight and try it in the morning. Dash lights have never been brighter....but bright is a relative term.
Old 04-14-2017, 10:18 PM
Captain_Slow
Cleaned the rheostat well...got it looking shiny again. Applied Deoxit last night, then flushed it out again, then more Deoxit. Installed the rheostat this evening and the instrument and console lights came on at the full max brightness position. Attempting to dim the lights makes them go out. I'll buy a new one...or live with the fuse bridge for awhile.
Old 04-14-2017, 10:34 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
to make the potentiometer work take a punch and reswage the rivets, then test it
Old 11-07-2020, 02:22 PM
mhousny
mhousny's Avatar
Originally Posted by Captain_Slow
It was the dimmer potentiometer. I followed a post suggesting I remove the connections from the dimmer and bridge with a 5 amp fuse. Instrument lights restored. Very dirty. No hurry to replace it since it adjusts between dim and dimmer.
Hello Guys, my name is Mo. Sorry ti come back to the issueI have a 1984 928S. I have the same issue as the Captain. The cluster lights are off as well as the HVAC’s. The sig lighter’s light, the shifter’s and the pod’s buttons are on. My potentionmeter is all aoxydized and is in the worst state. I removed it as I am planning to use a led dimmer. I tested the two wires and the black one has current whereas the Blk/ blue does not. I also bridged the two wires by it still does not work. Is it the blk/blue wire that is is diffective or is it something else? Thanks in advance
Quick Reply: instrument cluster lights out - Ashtray light still working
