No reverse lights
No reverse lights
My 85s3 reverse lights are non op, have checked the fuses, relays, all ok bulbs good, also changed the reverse light switch, still nothing, AÀAARRRRHHHH. SO FRUSTRATING by the way it's a 5spd.
Gotta get the wiring diagram out and check it out at each step along the way.
It could be the 4-pin connector at the front-right of the spare tire well. You can check the action of the switch there, too. Unplug, clean and re-plug.
Try trace the wires from the gearbox switch back to the connector in the spare wheel well. Two wires, running above the gearbox, look for a break in a wire and poor connection at the switch
I had problems with my reverse switch also. Still do somewhat. I also replaced the switch. I seem to remember there being a little actuator rod in the switch. If it went in too far the reverse lights would always stay on. But, if I backed the switch out some (not screwing it in all the way) the lights would not work. I added a thin washer and found the sweet spot. Not sure if this was the "correct" fix but it seemed to work. I still have intermittent working reverse lights but if I hold the gear shift **** tight in reverse, the lights stay on when reversing.
Team Owner
before you get to far inspect the 2 wire plug on the bottom of the steering wheel lock cylinder if its loose or not connected this could cause the reverse lamps to stay off.
I chased this with a 1986 machine and found it.
on mine the wires were just loose enough to not make contact,
putting them into the switch then all the lamps worked
dukenukemx (10-23-2019)
